I am sorry for the noob question, but what is this used for?
From my understanding it exceed by a factor of 10 any FV-1 you could dream of.Right now it is a build for people that want to experiment with programming a new generation digital sound processing chip. Possibilities will equal and exceed anything that can be done right now with a pedal that uses the FV-1 chip.
Got my Terrarium built today. Tried out the toggle / footswitch example. Worked first try. I'm going to write a test program this weekend that tests all the controls a simple boost. This will test all the controls and the audio. Will post my code. Next week, I'm gonna code an echo of some kind.
Sadly, I'm not a real coder. More a server guy but I can jump into other's code and change a single value...I'll set up a github repo, this weekend. That way we can work on stuff, together. I have tons of programming experience, some dsp, a lot of embedded experience and some ideas. Always open to ideas. It'll be cool posting code and getting critique, right away. I'm thick-skinned - don't mind criticism. The code ain't good until it does what you want and it's different for everybody. Hopefully, we have dsp guru or two in the group. I have 2-3 buddies that rock at dsp. BTW, I have sound passing through. I'm busy tonight or I'd get the pots and toggles going.
That's a shame! I would cannibalise another pedal if that happen to me!Still waiting for 1/4 jacks...
I'm using linux. What platform are you using? I've made 3 small apps but haven't done anything complicated.Anyone have a bonehead simple example of getting something together and pushing it to the pedal? I seem to be able to use the ElectroSmith web app to install stuff. What to you use to compile the terrarium.h file to a bin that can be pushed to the pedal?
