dawson
Hello, thanks for reading:
I've finished my Hydra build but when I activate it, there is no delay effect. The signal passes and the "Level" control works. The "Mix" control passes unaffected signal at full CCW and fades to complete silence at full CW.
I moved a couple potentiometers off-board to change the layout slightly but I can't imagine that's part of the issue..
I measured all resistor & capacitor values before installing.
I've triple-checked the resistor color-codes.
I've replaced both TL072's and the regulator with no change in behavior.
I've connected the right side of R5 to ground as suggested here: https://forum.pedalpcb.com/threads/hydra-delay-not-delaying.3041/#post-24502
but nothing remarkable happened- no sign of the stock FV-1 settings.
Has anyone experienced this type of thing before?
Any help would be much appreciated.
Here's a picture:
Here's a picture:
