So the outside lines arent connections?Use the perfboard one even though they’re virtually identical. It’s easier for me to see what connects to what. Ground makes a ring around the whole board. The connections for pots and 9v are inside that ring.
Got a little confused tracing both perfboard ones in my head until I realized the bottom one is reversed which makes sense
The connections to the hardware are shown as the open dots, but the upper right drawing should not be showing the three dots at the top of the green ground loop.So the outside lines arent connections?
I'm always looking for mine. I'd swear someone was moving it if I didn't know better.I need more coffee. Or less coffee. Quite a predicament
