kerryfine Well-known member Mar 25, 2024 #1 Just finished building the Hydra Delay. I get signal through on bypass, and signal when pot set to fully dry. No signal with Wet. LED lights up. Using 9V center negative adaptor. Attachments IMG_7669.jpeg 488.7 KB · Views: 18 IMG_7670.jpeg 546 KB · Views: 19 IMG_7672.jpeg 507.2 KB · Views: 19 image.jpg 476.8 KB · Views: 18
Robert Reverse Engineer Mar 25, 2024 #2 Use a jumper wire to ground the right end of R5 and see if you get a wet signal. It won't be the Hydra algorithm, but it'll determine if the problem is the EEPROM. Upvote 0 Downvote
kerryfine Well-known member Mar 25, 2024 #3 Robert said: Use a jumper wire to ground the right end of R5 and see if you get a wet signal. It won't be the Hydra algorithm, but it'll determine if the problem is the EEPROM. Click to expand... No signal still Upvote 0 Downvote
Robert Reverse Engineer Mar 25, 2024 #4 Can you take a picture as close as possible to the pins on the left side of the FV-1 IC? They almost look like they didn't all get soldered. Upvote 0 Downvote
chris.knudson Well-known member Mar 25, 2024 #5 I see flux residue all around the chip, but I agree that it looks like it's just sitting on some of those pads. Upvote 0 Downvote
kerryfine Well-known member Mar 25, 2024 #6 Robert said: Can you take a picture as close as possible to the pins on the left side of the FV-1 IC? They almost look like they didn't all get soldered. Click to expand... Ahhh you guys are right, that whole side was not soldered! I ordered it as presoldered so i didn’t even think that would be an issue there. Would that be a reason the EEPROM is reading 0 voltage across one side of the chip roo Upvote 0 Downvote
Robert Reverse Engineer Mar 25, 2024 #7 Pins 1 - 4 of the EEPROM are grounded, so that's normal. Shooting you a PM. Upvote 0 Downvote
