Hi everybody.
I have no delay whenever I activate the pedal or not.
Tried to connect to ground the right side of R5 (the side that is connected to the FV1): no change. Do I have to keep the connection or only touch the right side of R5 and the ground with a wire?
I soldered by myself the FV1, but I checked the connections to the board and everything is ok. Someone can explain me how to check If I burnt the FV1?
Tried to move potentiometers and switch: Volume and Mix only modify the volume of the clean signal. The others switches and potentiometers don't do anything.
Thanks
Thanks
