If this prompt doesn't summon him, Direct message
@RetiredUnit1 he has all the links to info an d schematics and tons of experience building tube amps.
A 5F1 Champ is a very small amplifier, meaning smaller chassis, fewer tubes, fewer caps and resistors, less expensive transformers. Mojo has the plans available online, I'm not sure if there is a BOM but it's very easy to do the same sourcing we do for pedals and put together a BOM from the layout.
As you can see from the files below, which you can save to your device, there is everything you need for sourcing parts and a 'how to' for putting them together. Why pay someone else $450 to put those parts into a cheap plastic organizer?
Purchasing the parts individually from
https://www.amplifiedparts.com/ or if you have a business license for electronics you can send an email to
https://www.cedist.com/ and ask for a wholesale account to $ave Buck$. CE Dist is the original wholesale division of amplified parts. CE Dist was first 25 years ago, and then about 15 years ago they started the retail outlet.
I am getting ready to build a champ, hopefully this year so I could come up with a BOM of the parts you need. I'm retired, nothing to do but clean house and build amps, so why not?
This is a very low resolution image of the one I'm going to be building, it is very different from a kit. It has Rob Robinette's 1/4 power mod, a line out, IEC socket, DPST switches, a 120v LED indicator, a star ground on a 1/4" bolt with the proper ground sequence to prevent ground loops, backup diodes, a cap to suppress standby pop and internal fuses for MAINS and HT.
And a LARGE 1950's pastel GREEN TITLE. The preamp and power circuit are identical tho.
Well, I gotta go mow the lawn and get the chores done. BUSY today!!!!
Edited: I realized I had not numbered the grounding lug order, so I did that today and added the note at the bottom explained the process.
