I was doing so well. Guardian, Paragon and Paragon Mini, Pyrocumulus, all working perfectly, barring a minor shorting issue when boxing my Paragon Mini, but General Tso is misbehaving.
Sound bypassing no problem. No effect when engaged. LED comes on, Dry signal still comes through. When in blend mode, the dry signal is off with the balance pot at full CCW and 100% at CW as it should be, but no wet signal. When in “Juicy” mode, the signal is just dry, same as bypass. Treble control has no effect as far as I can tell and nor does the sustain.
Unfortunately, these things always happen to me when I have tested my wife’s patience to the point where I am summoned away from the bench, so I will update with pics tomorrow. Very frustrating. I was looking forward to this one. Any ideas off the bat based on the symptoms?
