it is the wire that comes from the ground side of the LED to the footswitch. when the pedal is engaged the wire connects to ground and completes the circuit for the LED to turn on.
Ah, in that case, does it matter which 9V lead I connect? Either the one reserved for the power supply or the one pictured above, going to the board? Or should both be connected to the same block?
