They were on the home tab yesterday, now on 11.11 tab of the app.I didn't see this thread til now, Sun 12 Nov @ 00:53...
I already was on it for the Gonklonulator.
Wish I'd seen this thread and those clothespegs before placing my order.
@jwin615 Not sure what coupons you were referring to, but I now see
SALE IS ON TO NOV 17
Hmmm... so much more...
must...
focus,needs...only!
Do you have an electric screwdriver recommendation?The main non electronic precision screwdriver I use
Yes, the arrowmax ses mini. I use it everyday. Best form factor / comfort in hand of any I’ve bought and I’ve owned 3 others. Meant to suggest it after the non electric one: https://a.aliexpress.com/_mPVp2pKDo you have an electric screwdriver recommendation?
Got any pics of these in use?I use these to test populated boards. Cheapest I've seen them(~3)With a handful and some Dupont wires, I can hook up a board in just a few seconds while not having to solder any jacks or footswitch.
I do trim the edges and sides down with a Dremel to get them to fit between the upper pots for power on ppcb boards. Be sure to get 2.54 pitch. Really the fastest and cleanest way I've found to test boards.
No. But I'll try to remember (what were we talking about?) To grab some in the next couple days.Got any pics of these in use?
If these were kindly redesigned by our 3d printer capable brethren, they would be, by far, the easiest test bed platform.
I've gotten pretty quick with the Dremel on them, about 3 minutes each, but it does weaken the pcb.
Note that I have, as can anyone, use them with 3pdt daughter boards to fully test a pedal without any soldered wires. Used on madbean as well. Takes 10-15 seconds to setup without any soldered wires to fanagle.
Not reliable on pedals with odd(non flush edge) DC in points, but I've moved to using headers on most pedals with DC +- adjacent to each other.
The pcb redesign is pretty simple and honestly doesn't get in the way on most builds. *But* you have to trim the pcb to get the plastic trimmed.I might take a stab at trying to redo the PCB parts of it so it’s more of a T shape as opposed to a square. Saw some listings for unassembled versions and it started to make more sense. My order of them should be coming next week
Here is a standard ppcb 3 knob, the peach fuzzI might take a stab at trying to redo the PCB parts of it so it’s more of a T shape as opposed to a square. Saw some listings for unassembled versions and it started to make more sense. My order of them should be coming next week
Generally, the lower pcb mounts just need a bit to trim on the bottom of the clamp to avoid solder points of thoser components.I might take a stab at trying to redo the PCB parts of it so it’s more of a T shape as opposed to a square. Saw some listings for unassembled versions and it started to make more sense. My order of them should be coming next week
Yeah. Same idea. It's basically just getting someone to make a 4P one thats clamp will squeeze between 2 pots(or getting you to change your layout for DC ¿?)This might be worth exploring.
PCB Pogo Pin CLIP - PCB Klemme by seba83e
BOM:2x M2x121x M2x142x STS Plus 2.2x81x Spring Ø 6mm x 203x HEX Nut M2x1.6www.thingiverse.com
Pogo Pin Test/Programming/Debug Clip by Viper_7
Programming clip for connecting to headers on various PCBs without soldering any pins in place. Great for testing out Arduino modules and for programming microcontroller modules such as STM32 blue/black pills. Potentially quite useful for educational applications, allowing students to connect...www.thingiverse.com
Shipping doesn’t combine on multiple. Still winds up being and $35 per enclosure
It says "height 30cm" in the text. So the model must be tiny.DEFINITELY GETTING ONE OF THESE FOR THE DRUMMER! It's his spirit animal.
https://a.aliexpress.com/_msRTKuY
