JHS Pedals Overdrive Preamp
Because the whole pedal is a Red Herring. It does nothing, but the player expects it to, and hears what they think they should be hearing. Its the REAL Placebo Pedal...
But but but, why would he lie about pedals he is selling way over priced pedals??? 🤣🤣
Reactions: spi
Here's some pics of the board. First one is an overview so you can follow along. Then there's three of each section that should be good enough for everyone to read the codes off the resistors and whatnot.
Kinda weird question, but... Have you played it so far?
Curious about the taper of the gain pot, as with lin tapers for both volume and gain most of the distortion would likely be after 3 o'clock and the volume will give you a false sense of loudness. Also, do you have any other DOD250 or Dist+ for comparison?
Curious to hear how much Gain with a B250K?
DOD 250 uses 500K, Distortion + uses 1M!
Every modder seems to use a C taper!
I built the AionFX version a while back. Also built an Irrlicht (EQD White Light) which is based on the Distortion+. Between the two, I preferred the Errlicht.
I did breadboard a stock 250 last week so I'll be able to compare for sure. Once I nail down this new-old one, I'll likely re-breadboard it and compare. :D
