@fig had a great idea that I used here. A daughterboard for all your pots, but will take up more workstation real estate. You'll also need male/female jumpers for that.This was from a while ago. Clark Gainster. I really need to start developing a neatness strategy, and making a breakout board to handle the potentiometers. Apparently this direct-to-breadboard idea isn't smart. I also ordered some proper jumper wires since then.
Please do if you have the time. CAD can be a pain sometimesI finished, now now, my aforementioned fuzz experiment. It’s based on the Bazz Fuss, with tone, master volume, and gain controls. The gain control blends the two stages.I can try to draw it up, if anyone is interested…
I’ll give it a go tomorrow. My plan is to try and perfboard this build up. My first “from scratch” build.Please do if you have the time. CAD can be a pain sometimes
Any transistor recommendations? Also, what made you alter the second collector to 560k? What kind of diodes did you like?I did my best. It looks a mess, but I'm 99% sure it'll work...View attachment 15447
All useful information that I forgot to add. Q1 (on the left) is a 5089. Q2 is a BC109C. The 560k resistor was to get Q2 to -4.5...I think. I have to fire it back up and double-check the voltage. The tone control just blends between high and low cuts. Diodes I used are 4148. I popped a few other things in (some GE...which didnt really work well, an LED...which didnt have much effect), but the 4148's worked best.Any transistor recommendations? Also, what made you alter the second collector to 560k? What kind of diodes did you like?
Sorry, also trying to wrap my head around the tone stack too. How does that work?
I'll definitely give this a whirl shortly. Thanks for sharing!!!
Tone pot is A, Blend is B, Volume is A...and thats only because those were what I had on hand. The tone pot should be a linear pot...Question: Is that an M or N taper pot?
