ValentinWFP
Hi there,
I've recently started building a lofi-nator and got the PCB and materials together as a kit. The problem I've got is that the capacitors C11 and C13 I received in the kit are electrolytic rather than non-polarised. Based on the docs (here) and the PCB, I'm under the impression that it's not a problem so long as I solder them with the right orientation; ie. with the - of C11 going to R30 and the - of C13 going to Q1 and R39. For both capacitors, that'd be with the - on the right when facing the PCB.
Is that correct? And if so, how much influence would this have on the signal/sound?
Thanks a lot
Val
Thanks a lot
Val
