BuddytheReow
Breadboard Baker
Finally got my small bear order in and need to measure pinout, hre , and leakage. I've got npn and pnp for both silicon and geraniums. Is there a cheapo one from Amazon you guys can recommend? Thanks
Will that measure germanium leakage?I just ordered this one. Won’t be here till Monday, but someone else around here has one…
https://www.amazon.com/gp/aw/d/B091281YKX?ref=ppx_pt2_mob_b_prod_image
I use the same one. Decent enough for Ge transistors, here is how I interpret the measurements:
I’ll let you know on Monday.Will that measure germanium leakage?
Germanium Transistors:
So not always the best for leakage, but it will give you a good idea of the comparative values between individual transistors.
- hFE - DC Gain - hFE = Gain parameter measured under DC conditions
- Vbe - Voltage b/w Base & Emitter - (mV) - 0.65-0.7V for Si, 0.15 to 0.3V for Ge.
- Ic - Collector Current used for test - (mA) - Most pedal transistors run Ic <1mA. Some (i.e. Harmonic Percolator) run below 100uA. Some testers measure hFE at 5mA or higher, which is not particularly useful to pedal builders.
- Iceo - Leakage Current at the Emitter - (mA) - Collector-to-Emitter current w/Base lead not connected to anything (an extreme case as in most circuits, the Base has a DC path to somewhere) - Anything <100uA is good
- Ices - Collector-to-Emitter current with the Base lead shorted to the Emitter - (uA) - Leakage Current in-circuit is somewhere in between Iceo & Ices.
How do the TC-1 Iceo & Ices measurements compare to R.G.'s leakage values?
Does it measure leakage?I honestly have the worst luck with these. I've had two of the model above and neither of them lasted more than four weeks. Both of them turned off during a test and just didn't turn on again.
I also had a TC7? I think that was the model number and the screen died on it. You could still just about see the text so it must have been the backlight.
I was going to buy a Peak Atlas but don't really have the cash at the minute and I need to test some transistors for a build this weekend. I thought I'd try one more and this guy turned up about 20 mins ago
I have a few issues so it's going back to Amazon tomorrow. Problem A - the battery cover won't fit over a 9v battery. As you can see below the battery sits higher than the shelf the flat cover slides over.
Problem B - The blue adaptor to connect the components was in the battery cover when it arrived. It just slides into some holes below it. Whenever you put a part in to test you have to hold the other side or it just lifts up when you lock a part in place
I know these are cheap but this one feels especialls pants
On the plus side it does seem to be pretty accurate.
Based on what I’m reading here and elsewhere there isn’t a Swiss Army knife type of tester under $35. I may just get a basic one and use the Geofex method of measuring leakage and just call it a day
