Lovetone Brown Source
I've had decent results, but a recent Big Cheese (Monolith) build went completely off the rails for some reason, and I'm getting less and less enamored of the AionFX daughter boards...
... and as I need both for my Cheese Source clone... ;)
I built one of the AionFX versions. It's a good pedal. Definitely has some great tones in it. :D
For sure.
My beef with Aion is the breakout boards. The rotary breakout board in particular drove me nuts and the assembly seemed needlessly fussy. Then the rotary switch went bye bye (not Aion’s fault obv) and the thought of trying to replace it … just no.
But it sounded great!
For sure.
I get it. That's a fair point. I certainly have had at least one experience with a switch messing up and having to replace the entire breakout board. At least AionFX sells them individually. But still...it would be nice to have the option to not have to use a breakout board like that. Heck, I'd settle for one that gives you the option of using wires to hook up the switch.
Which gives me an idea...why not just wire it up and not attach the switch directly? Granted, kind of a hack but does alleviate the problem
1590XX is doable by just building the separate 1590N1-sized FX. Then you can have complete independence with a normalised jack config, room for a loop-bypass stomper… not that those couldn’t be built into a single board, but what are the chances of having all your preferred options vs other people’s preferred mods?
Fucking “edit-post” is going haywire on me…
I'd done a double build in the 1590XX with an order reverser... but it is a pain in the butt... I do really like the idea of a single board. The way the Duo Phase is wired you could still do an order reverse two jack, or a four jack configuration...
And obviously use a switch/footswitch for the order instead of adding more jacks like the original.
Something like this... with fewer wires... ;)
Yes! Beautiful build. I actually have both of these Aion boards, along with the other lovetone Aion boards, mostly populated sitting in my work space waiting on me to decide if I want to build them in one enclosure like this.
