Hi all,
Been working away on a Low Tide and I am testing it. I have read through the forum and Im not seeing anything thats similar to my issue. I am getting an output. I seem to be getting a random warble but I would say there's no modulation just a judder in the sound from time to time. Rate seems to change this.
I have tried to follow the detailed instructions on how to uses the BBD and Gate trims. When Im adjusting the BBD the signal will get louder and clearer but there is always a hiss at the end of a note. Especially if I play a chord. Also the gate trim only works at 95%-100% the rest is silent.
I did notice when reading that when subbing a J201 conversion board sub for the 2sk208-y i needed to cross the legs for S and D so I have done that, insulating one leg. I have also noticed people taking voltage readings of the ics and Q1-4 so I will do that below for the Qs and IC7. In the below i have set all then knobs to 100% ;
Q1: D- 260mv / S- 7.6v / G- 0.2mv
Q2: E- 7v /B- 7.65v / C- 9v
Q3: E- 3.4v /B - 4v / C- 6v
Q4: D- 5.75/ S- 200mv / 0.5mv
Q5: E- 5.1v / B- 5.75v /C-9v
IC7 - MN3207 -
1 = 0v
2 = 2.44v
3 = 3v
4 = 4.6v
5 = 5v
6 = 2.4v
7= 3v
8 = 3.2v
Im relatively new to pedal building, first try with ICs. Any help would be magic and if anyone needs more info or reading I can get them.
Cheers
Graeme
IC7 - MN3207 -
1 = 0v
2 = 2.44v
3 = 3v
4 = 4.6v
5 = 5v
6 = 2.4v
7= 3v
8 = 3.2v
Cheers
Graeme
![IMG_3903.png IMG_3903.png](https://forum.pedalpcb.com/data/attachments/31/31923-2a2ddf940be1e830f9227969f67b3132.jpg)
