What is VREF? Anyway to check the ICs in or off the board?
re:VREF
An audio signal swings both positive and negative voltage relative to ground.
An op-amp can't amplify a voltage below the negative supply or above the positive supply.
Most op-amps in guitar pedals have a negative supply of GND (0V) and a positive supply of ~9V.
So pedals will supply a VREF voltage that is usually 1/2 of the input voltage by using a voltage
divider with two of the same-value resistors. R101 and R102 in this circuit create the voltage
divider in this circuit.
By referencing the incoming signal to 1/2 of the incoming voltage, the op-amp can amplify it in the
negative direction but still have that voltage be higher than the negative supply (which
is zero, GND). So for example, you reference your incoming guitar signal to 4.5V, you can amplify it to peaks
of +/- 4 volts or so, from 0.5 volts at the low points to 8.5 volts at the high points. In the median compressor,
R14 is an example of this, it "pulls up" the incoming guitar signal to VREF via a 1M resistor right before
the op-amp input. Then at the output of the op-amp, you use a capacitor to remove the
VREF offset - if you look at the schematic you can spot this pattern very clearly at IC2.1 and IC3.1.
If you didn't reference the incoming voltage to VREF and tried to amplify it by the same +/- 4V, the high
peaks would go up to 4V, but the negative peaks would stay at 0V, so you'd have only half of the
signal.
Some amps/pedals use charge pumps or transformers to give the op-amps a negative supply that is
negative relative to ground so there's no VREF needed, but that just trades one kind of complexity for
another.
The formula for calculating a resistor divider is (Vin * R2) / (R1 + R2) = Vout so if R101 and R102 are
both 10K you'd get (7.7V * 10K) / (10K + 10K) = 3.85V. In your case if R102 was 10R you'd get
(7.7V * 10) / (10K + 10) = 0.007V.
re: testing the ICs.
If you pull them and things measure way different, you can try moving stuff around or working by
the process of elimination. (But fix R102 first) If you have another guitar pedal somewhere that
is socketed, you can swap in the ICs. Dual op-amps all have the same pinout so they're swappable.
