vigilante398
Authorized Vendor
Methinks you swapped those around. Per Robinette's design 12AY7 and half of a 12AX7 is preamp, 12AU7 is the power tube. 12AX7 doesn't make a great power tube.12au7 in preamp and 12ax7/12ay7 in power.
12AU7 is rated per the datasheet for an absolute max 2.5W output, but I'm not sure the Hammond 125B is the best transformer to take full advantage of everything you can squeeze out of it. I mostly see amps like this labeled as everything from 1/4W to 1W, never higher.
