Robert
Reverse Engineer
Or maybe see the schematic?…
@Robert any update on the Binaura build doc please? Would appreciate the schematic, BOM and a drill template please. Looking forward to building it.I'll get it posted ASAP. Is there anything specific you need to get you started?
Thank you! Luckily I have most of that on hand thanks to the Protoboard build, and FV1 development board builds. Only thing I need is the DC converter.Yep, I'm working to get those (that and the Isolator) posted today.
The BOM is simple, I just have to finish up the drill template since you'll need appropriately sized hardware for mounting.
So, following that bom, the output would be 12V ? Using the IEB0105S09 would give me a 9V output for most pedalsYep, I'm working to get those (that and the Isolator) posted today.
The 12V output is regulated to 9V by the L7809.
So in the 4 tap, the regulator brings the voltage to a certain level (5V ?) and then converters are used to get a specific voltage and mA output on each tap? Or I am completely off ?You want the IEB0105S09 for the 4 Tap, I'll get that one posted shortly.
So ... there are a few parts with the same spec. the XP Power IEB0105S09 at 3$ (in Canadian), the XP Power IE0509S at 8$ and the RECOM RO-0509S at 10$. any reason to pay the extra dollars or the 3$ one is a good long term choice.You want the IEB0105S09 for the 4 Tap, I'll get that one posted shortly.
Thanks!Schematic is here:
BOM is here:
Drill template is here:
For the 4 tap, in the pending build doc you list "L7805CV" which is a 5V voltage regulator, should it instead be "L7809CV" which is 9V?
