The Footswitch on the Right is Standard IN, GND, SW, OUT & you can use the 3PDT Breakout Board if you have one!
The Footswitch on the Left needs to be Wired as Pictured below:
Thank you all ! In the left switch I can use a DPDT? The two wires on the left are to switch the boost an the two on the right are to switch the led. Am I right?
