How do you know that the Mojito is a Dumble style overdrive?? I can't see any info describing it anywhere...
I have an original Simble and planning on building the Symbolic from PCB. If it sounds as good as the original, I will sell it to fund 3 pedal projects. If it doesn't sound as good then I will kind of be SOL. It probably makes more sense to do the Shin's Dumbloid pcb since it is a much more expensive pedal. I just don't know if it is better since I've never seen one.
