MichaelW
- Build Rating
- 5.00 star(s)
So when I built the Cattle Driver I had no clue what it was. It was a purely impulse buy after learning it was a clone of the Buffalo FX TDX, which is a solid state clone of the BK Butler Tube Driver.
Little did I know the rabbit hole that pedal would send me down......and I'm still working my way out hahaha.
I've become fascinated with the TD-X, the Tube Driver-like overdrives.
Since building the Cattle Driver, I've built the Grover Drive, the Cowpoker, and now adding this to my list. The PedalPCB Mosfet Drive, @Robert's take on emulating the BK Butler Tube Driver. But this Mosfet Drive board has been out stock for a while now. @Robert knew I was waiting for it come back and so he sent me one when they arrived. WOOOHOO!
It came in the mail today and it just so happens that I had an enclosure already drilled for it (from my failed 4 Knob Celestial Drive build.....)
So barely was it out of the hot little vacuum pack before I started putting together the parts to build it out.
It's a fairly simple build and went together quickly.
So does it sound like a BK Butler Tube Driver? mmmmmmmmmmmno....not really, but it's a GREAT sounding pedal!
(To be fair neither do any of the other Tube Driver emulations I've built heh.)
So I was chatting a little bit with Robert about the biasing, I thought that the trimmers were to bias Q1 and Q2 (I mean I think the build doc actually says "BIAS"). I had originally biased the Drain legs of the BS170's to 4.82v. Well turns out according to Robert that they're really mini gain trimmers, as opposed to bias trims. So he recommended to start at zero then dial up to taste. WOW that changed the whole nature of the pedal for me! The way I had it originally set it was an aggressive trebly distortion. (Not unlike the CowPoker, they have the same philosophical roots). But dialing the trimmers back to zero then cracking them up a wee bit at a time (they effect different frequencies) I have them "maybe a skootch less than 1/4 way open" and now the gain is warmer, fuller, more organic and LESS. hahah, I like that about the Cattle Drive that while it can get pretty gainy, it also sounds great low gain. The Mosfet is shaping up to be similar.
All of the Mosfet based pedals are pretty awesome in their own right and have their own thing going on. All great pedals.
On deck in this series I have the Finale Overdrive (Fulltone Hi-Mu), The Cliffhanger (not really a Mosfet drive but I'm counting it because it's supposed to emulate the pedal that emulates the Tube driver , the MBP Mysterioso. I "thought" this was a Mosfet based drive but now I'm not so so sure, I need to go look over the build docs again. And I have the MBP Archibald, an actual TUBE version of a Butler clone. So that will be interesting.
Anyway, great sounding pedal, treat the Bias trimmers as gain trimmers and you dial a really nice sounding medium high gain overdrive.
