Rando_calrissian
I just finished the build but it won’t power on where should I start?
It passes signal with no issue in bypassFound the power issue it was a broken wire but now it seems as it is in permanent gate mode and won’t open I will post pictures soon
Also pin 1 of the tl072 gives 0 voltageyes it is silent,
I’m currently going through the schematic and following with a signal generator so see where the signal stops currently at pin 17 on the that4301 I get a square wave at .8mv where at input I have 3v
At the output of that section pin 13 on the that I have 0
From the schematic it looks like a closed loop feeding into pin 5 of the that4301Pin 1 for a tl072 is the input signal. There may be a short somewhere prior to that. Pin 8 will have in the input voltage so that should be around 9v
Also my negative sources that should be -9v are reason -2.5v
