Rixroxx
- Build Rating
- 5.00 star(s)
I messed up getting the wrong decal paper. These two pedals ended up with no labels or graphic or whatsoever. Overall, both pedals sound good. The build and all are worth it. Never had hiccups after the first test of each pedal, it worked right away.
I found the Thermionic Deluxe B channel (lower gain) to have a great amount of volume over the channel A (higher gain) even compared to bypass volume. But this can be fix by adjusting the gain trimpot till both channel have the same volume when engage. I put header sockets on the LEDs to try swapping out using other diodes but ended up sticking with the LED. At both lower gain settings, I tried boosting it with my DIY TS808 and wow, it sounds round and smooth like YJM style.
I liked the Angry Andy Plus more. Much smoother and the dynamics is very good.
