Nutty fuzz: Pdt wiring issue?
cozycam
Here's some pics. I can post a video if needed. I think the issue is with my 3Pdt wiring but I'm not sure. Power led isn't in yet but I covered the holes and close the enclosure when testing.
Side note, Is the expression input meant for a 100k pedal?
PXL_20230505_112611915.jpg PXL_20230505_112634123.jpg PXL_20230505_112624171.jpg
Thank you. Dumb question, If I use a breakout board, is everything but the bypass (5th point on PCB?) the same?
Or should I just bite the bullet and wire it with no breakout board?
Here's how mine is wired, using the standard bypass breakout board
