O Twee D - AKA The Scrapyard Gentleman
SillyOctpuss
After originally asking for build recommendations in this thread
I was all set to pull the OCD out of the enclosure when I decided to give it another go. It basically sounded all fizzy and indistinct, like it was doing a really bad impersonation of my old OCD. I changed the IC - no difference - so then I swopped the 2N7000 for a different pair and damn me if that didn't do it! I swopped both sets back and forward a few times and the difference was huge. I'm planning on doing some recording tomorrow night so will do an A/B comparison and post them on this thread tomorrow.
Out of curiosity I put both sets in my component tester
Old set
659 mv between source and drain
vt = 1.71v
cg = 121pf
rds = 3.3 ohms
669 mv
vt = 1.65v
cg = 122pf
rds = 3.3 ohms
New set
683 mv
vt = 1.86v
cg = 65pf
rds = 2.8 ohms
685mv
vt = 1.88v
cg = 64pf
rds = 2.8 ohms
Now apart from the mv between source and drain I don't really know what the rest of those results mean. If anyone could explain it I'd appreciate it. I had another 10 2n7000 and they all measure about 122pf apart from the two that are now in it. They were in a separate bag from bitsbox which is why I happened to grab those- I'm not sure where the others came from and I haven't tested any of them in the circuit yet, I will when I get a chance tomorrow.
It's a bit of a recycled special this one much like the bad bob I finished a few days ago, the enclosure, jacks, switch and a bunch of parts have all been in other builds. I'm definitely digging having such a dirty pedal in a tweed box. Temporary knobs on it as well for now.
That turned out really nice!
Question: what or how are you cutting that board? Every way I try is either messy or ends up looking like I chewed it in two.
That's pretty rad - I really like the tweed job, I'm going to have to think of what else can be glued to an enclosure now.
@fig I haven't had to cut vero in a long time, but I do it with a metal ruler and a utility knife. Cut through the holes (as you can see in @SillyOctpuss picture) and not in the blank space. When you've scored it a few times you should be able to just snap it. I'd then run the edge of it along a piece of sandpaper to help smooth it out.
That's exactly how I do it. Occasionally you'll get a piece where it doesn't cut cleanly and I tidy the ragged bits up with some sharp snips and a bit of sandpaper (if required).
I've got a double tweed pedal in the works which should get finished next week and as a sneak peak I was experimenting with this tonight - it's really hard to photograph in this light but it's self adhesive gold carbon fibre affect. It's much cooler in front of you than in picture
Old set
vt = 1.71v
cg = 121pf
rds = 3.3 ohms
669 mv
vt = 1.65v
cg = 122pf
rds = 3.3 ohms
New set
683 mv
vt = 1.86v
cg = 65pf
rds = 2.8 ohms
685mv
vt = 1.88v
cg = 64pf
rds = 2.8 ohms
Click on Edit, click on the picture & you should see a outer highlighted line (box)/
Go to one corner & click on left mouse button & shrink picture.
Reactions: fig
Neat enclosure! This is a silly question but what kind (brand?) of resistors are the slightly greener ones? I assume a particular brand just uses a slightly different color or something.
I think they're TE Connectivity. They were the best priced Resistors at RS Components in 2016/2017 which is when I stocked up last.
