Hello everyone!
So I had a fun day building my first ever pedal and of course it isn't working.
I have double checked all component values and polarity where applicable, checked connection points for dry joints and bridges and tested resistors for faults with my multimeter. Also double checked wiring for 3PDT switch. All seems fine.
I didn't want to be that guy and come to the forums asking for help without checking everything I could think of and read online, but I'm at the end of what I think I can do with my limited knowledge. I'm hoping it's just a simple n00b mistake with the components I've chosen as I have noticed a few issues...
So just to quickly outline the situation:
Any help massively appreciated!!
- I'm getting no LED light (have tested, lights up with continuity test, also definitely correct polarity).
- I'm temporarily using a 3PDT toggle switch as my footswitches are delayed, but I don't think that would cause an issue? Tried both with a 3PDT daughter board and by wiring 'manually'.
- In the 'top' and 'middle' positions I get a loud buzz and hum, and in the 'bottom' position I get a quieter buzz and hum that gets louder when I touch the strings or whatever earthed bit on my guitar. No guitar signal at all that I can hear on any setting.
- I have noticed looking at pictures that some of my capacitors don't look like the capacitors that others are using, even though the values as far as I can tell should be ok (same farad value, voltage rating fine). I actually think this must be where I'm going wrong but I'm too inexperienced to know why exactly! I did notice there were polarity markings on the board and a few of the caps I used were not polarised so yeah...
- No signal comes through the pedal when switch is in off position or when there is no power connected.
- My B2K pot is annoyingly a different size to the others, but can be wiggled into the right position to go into the enclosure, so that shouldn't be an issue at all, just mentioning it as it looks weird visually.
- Soldering is a bit rough, but as I say I did check all joints and redo a few to be sure.
