Cobalt 9v Battery Power?
ShredEd
Hello PedalPCBer's! I just built the Cobalt drive and passthrough and LED works but zero sound when switched on. Nothing at all. Since I don't have an 9v AC power adaptor, I just wired in a 9v battery. Might be a dumb question but should a 9v battery be able to power the Cobalt just as well as a 9v AC adaptor? I have triple checked components and also checked for shorts / polarity. Stumped but thanks!
Having a build that works in bypass but no effect when engaged is a common problem.
Check some other trouble-shooting threads with the same sort of problem for possible solutions.
Common human errors:
Plugging into the OUT jack and coming out of the IN;
Not having GAIN or VOLUME turned up;
Forgetting to put in the transistors or ICs after soldering in just their sockets;
Solder-bridge dumping signal to ground (bridge hidden under a component/socket)...
As already suggested by Robert, pics are needed, or we can just keep shooting into the dark...
The underside. I realize my soldering doesn’t look the best but I think they are all solid. Any insight is appreciated. Thank you!
Update. After fiddling for hours one issue that I discovered was that I was using a crappy zinc, although relatively new, battery. After installing a stronger alkaline battery, I can hear the guitar when I turn on the pedal but it’s much lower volume than bypass and the controls do nothing. I’ll search the forums now. Thanks!
