Pedal2222
Thanks!Late to party but GORGEOUS.
Thank you! I bought the leds and the reflectors at ebay.Would you mind sharing those really neat LEDs and LED bezels? They are the icing on this beautiful pedal-cake.
Amazing build.I've used the original analogman k.o.t. v4 schematic and changed the paragon power supply with four jumpers. I soldered a 1N5817 diode directly to the power socket +9V (D7, D14, D15 are jumpered). Just like analogman I've used two electrolytic capacitors 100uF/50V for the power supply. C21/100uF is for the main power supply including the led's. The jumper on IC pins 2+3 connect C21 to ground. C11/100uF (stock) is for the voltage devider. I wouldn't change anything here, but there are other ways to jumper it to get the same result.
Thank's!Amazing build.
I’m curious about a couple of things as i want to build this same build.
1. Why are some resistors socketed?
2. What’s did you mean by you soldered a diode direct to the power socket? I’m not sure i understand where the 1n5817 is located
yes, but I wanted it that way. It could of course have been solved differently. I've already described the omission of the charge pump, the rest corresponds to Analogmans k.o.t. v4 schematic.You know if you left D7 on the board, you would not have to mount it outboard on the power jack. When you say you used the Analogman v4 schematic, what parts did you change from the PedalPCB build docs? C1, C12, R3, R17, anything else?
C1, C12 = 10nWhat values did you use for C1, C12, R3 & R17? According to this (alleged v4) schematic, those are all different from the Paragon's BOM. I'm not criticizing, just asking.
Yes, possible. I have to open my original k.o.t for that. I've adopted the values from there. It can take a while..
Hi!Love this build, thanks also for providing all that information on the modifications you've made.
I was hoping you could help with two questions:
1. When you turn up gain and tone on both sides (both sides engaged), does your build squeal or oscillate? Any difference with or without a buffered pedal before in the signal chain?
2. You mentioned that you have an original KoT, any oscillation/squealing on that with the controls dimed?
The squealing issue seems to be present with many KoT clones (don't think on the original, but haven't been able to confirm), including the paragon (here and here). Very curious to hear if your modifications fixed this problem!
Hi,Hi!
No, I have no oscillation/squealing problems at all. Do you have build the paragon with or without the charge pump? I tryed a buffered booster pedal in front of my paragon and original KoT also, the amont of hiss was a bit different, that's all.
Thank you, you're welcome.Hi,
that's really cool, thanks for testing! I actually had this issue with a slightly different KoT build (Fuzzdog Emperor), even with the charge pump removed. Trying to find out if the Paragon has the same issue, I came across some forum posts that suggested it has the same oscillation problem.
Thanks also for confirming that the original doesn't suffer from this problem, I always assumed that, but could never confirm.
Just ordered a Paragon PCB plus a bunch of those Dale resistors, love the way your PCB looks!
Thank you! I have used panasonic smf caps.What a fantastic and beautiful build thanks for sharing! Very helpful too as I want to build one of these and bypass the charge pump so thank you for sharing that.
What type of film caps did you use? They look like panasonic but do you know are they the polyester or are they like polypropylene or something like that? Thanks
Thanks so much for the response! These must be no longer be produced because I'm having a tough time finding them anywhere. Any ideas?Thank you! I have used panasonic smf caps.
Gorgeously clean work! I’ve yet to build a Paragon, but I’ve got a couple on the way. Very excited for it.
They carry Panasonic film caps yes but the SMF seems to be out of production along with the ECQ-V. Wondering what the best replacement is since these are hard to find nowMouser and Digikey have those I believe. Tayda has other Panasonic series. You can find other vendors on Google I think.
