Hey, new here. One question: the build doc says MLCC...but this doesn't necessarily mean it has to be SMDs, right?I think this points up an opportunity for improvement in the build docs: list the capacitor type. The Arachnid board does this in the case of the MLCC capacitors. Of course, we are always free to upgrade cap types as long as they will fit.
BTW, the dead giveaway for electrolytic capacitors is the polarity mark on the board.
Thanks!!!No there are through hole MLCCs (usually the little yellow ones)
The electro spaces usually have a square eyelet and a round eyelet, and a circular outline and a + - polarity marking. Some pcbs have a bipolar cap with a circular pcb outline. Generally, if you have a box outline, it will be a poly box or film cap (63v or 100v rating are generally good) unless it is less than 1nf (e.g. 100pf, 47pf etc.) If there's a schematic, electrolytic caps have a distinctive -I(- or -)I- marking as opposed to a non polarised cap which looks like -II- on the schematic. Please excuse me if these are things you already know.That they are. In general though aren't Xu caps electro? And Xn film caps? Not being snotty, just want to make sure I get it right.
Also there are many other 1u rounds caps in the build. ie C20 is 1u but electro and all there are 1n for film.
Other than the markings on the PCB how would you know that 'this' 1u is a film cap but all the others are electro even though both are 1u?
1UF 50V MULTILAYER MONOLITHIC CERAMIC CAPACITORMine are blue, I hope they sound ok! I used to think that MLCC stood for Multi Layer Chip Capacitor, but it's actually Multi Layer Ceramic Capacitor.
A couple things to note about MLCCs:
- MLCCs are good in switching power supplies and high-speed digital circuits where performance at megahertz frequencies is important. They are not particularly well suited for audio circuits.
- MLCCs rated for <100V have reliability issues because the ceramic layers are so thin that they can develop shorts.
For my first Arachnid (Octagon) build, I followed the BOM. The ones I got from DigiKey (FK24X7S2A105K) are rated for 100V. Next time around, I'll use film for all of the ones in the audio path.
Where do you get em from??I always make sure to buy C0G or NP0, class 1 all the way baby
