Pedal popping fixes??
Good evening,
I've used 3 different PCB manufacturers so far and I seem to encounter engagement popping with the majority of my PedalPCB builds (Modus Operandi, Transcendence, Arche, Shrapnel, Guardian, Magnetron, Spirit Box, Duocast, Ocelot, etc...). The circuits sound fantastic once they're on, but engaging a pedal in the middle of a song, and hearing that pop, is a bit of a nuisance.
I searched through some of the posts and I see that a 100k resistor on the output is a common fix - as well as switching to tantalum on some of the electrolytic caps.
Question is, "where is the best place to place the 100k resistor from output to ground?" Should I put it on the footswitch PCB? Do I need to go directly from the output pad on the main board?
Thanks for any help you kind folks can offer? I'm asking here because I'm not experiencing this issue with other PCB manufacturers. On some of the problematic builds, I've tried 3 different brands of 3PDT footswitch, soldered transistors instead of socketing them, put on some additional RPD, etc... I'm wondering if I'm building all of these pedal incorrectly. Thanks again. (Pic is the latest build - Guardian)
I’ve read that the last electrolytic capacitor in the circuit can cause issues…especially if it’s a cheap capacitor. They can hold a residual charge that can cause a pop when the switch is pressed. Need to look into this since I have quite a few that use tantalum instead of electrolytic.
Definitely looking into that. Thank you.
Popping switches are sometimes mysteries unto themselves. My circulator pedal only stopped popping after I put in a soft relay switch. For this question it is odd that the popping only appears with some PPCB boards, but it may have more to do with the parts sourced for them at the time.
This worked for me when nothing else would. It's super simple...
I was looking for your post to share on this one!
Just disconnect the LED temporarily, if the popping continues swapping the color won't help.
When I took out the LED, the pop went away... therefore I proceeded to swap colors. First Ultra bright blue, then ultra bright red, then red diffused. They all popped the same. I even tried the Muzique method mentioned by tying in a 390R resistor and a 33uF cap to ground. It still pops...!!!! Next step might be to swap out the 4u7 caps for better quality ones.
No need to change those two, C11 is responsible for blocking all the DC to the output. Strange that the RC filter on the led didn’t fix it even though removing the led did.
This is great!!
How would I use this with a PPCB board? They have the standard 4 pads at the bottom and the 2 pads for LED?
This is great!!
I'd remove the LED from the PCB; wire power and ground from the DC jack to the PCB as usual; omit the LED connection to the footswitch from the PCB; then wire everything else as shown in the diagram. If you're not familiar with vero builds this would be a pretty easy one to start with.
