Svenson007
Hello out there pedal freaks
About two years ago I fell in love with Frantone pedals. I’ve built mostly the Cream puff and (I think my favourite Peach Fuzz often on vero board)
I was building the pedal pcb Cream puff’s. I was always hoping for more frantone cuz pedal pcb is my fav. But I could only find a pcb for the Peach fuzz on PCB mania. That’s not idea for me. But it worked well, if a little clunky.
One day it happened. The Persica was posted (peach fuzz) so I ordered a handful of them. Making double pedal plans etc. thing is it is still in the “experimental” stage. Which means no documentation etc. just the components printed on the board. One thing I noticed right away is the Opamp said TL022. So after some research I found out that the TLC2262 (which is in the frantone and pcb mania) should be no problem. All the other components seemed to be the same. The TLC2262 was the default ship for this build… but is it possible the TL022 printed on the board is for a certain reason? I even read you can use a simple tlo72 so I doubt it.
So I built one very carefully. Then I move on to testing. I’ve always just tested using alligator clips to wire, then into the input and output. The other ends to the jacks. Under fresh battery power. Works for me. To my dismay there was very little volume at all. The circuit is powered by two Lm386 chips (along with the TLC adding the character). So I assumed I must have the wrong version of the chip or something. I kept swapping and swapping different 386’s and no volume increase. I have a few pcb’s so started from scratch and the same results. Very low volume.
I just happened to receive an audio injector pen the same day. TC customs makes a sort of all in one audio probe. So I used it to probe my way through the circuit. At some points it would be about as loud as you wound expect… not so much at others. I noticed with R6 (forget the value) it was much louder. The one makes this annoying ambulance sound. It was strong and distorted.
Anyways since there is no docs yet I’m wondering if anyone else has built this pcb and your results. My two are identical besides 386’s for experimenting.
Just sucks as I was so pumped and had been planning, and ordered cases for double frantone / order switcher mode builds.
That’s the risk of buying in the no docs state. But I felt I had a pretty firm grip of the circuit. I’ll attach some schematics from other sources etc… and hope we get a pedal pcb version soon. It such a simple pedal I don’t know what could go wrong…. Twice. Some pics will be from pcb mania (components)
Again when I would probe R6 it was pretty loud and distorted. Hooking the other end of the probe I had no problems making my way through the whole build. So no bad components etc.
The board marked TL022 makes me wonder if the pin outs of the IC’s are a problem? The consensus out the is no. But can’t see what else it wound be .
Thanks for listening to my blabbing, I was just really stoked on an idea… so naturally I’m bummed.
Any hints, guesses … anything are welcome!
P.s the last one has its saturation enhanced so colour bands are more visible. I didn’t get a shot of the back because the soldering is sound. And also with my probe my signal makes it from IN to OUT.
Cheers!
Cheers!
