Coda
Yep. It's a real stumper. I'll figure it out eventually. It'll work when its ready to work...I know it's really boring, but did you check every resistor and capacitor? Changed every single Opamp?
I don't know if it is the case, but it's worth a shot, I got a Muzzle PCB with one track without continuity. A small jumper solved the problem... I know it's not that rare because I have this problem with some pcb I buy for my pedal line from time to timeYep. It's a real stumper. I'll figure it out eventually. It'll work when its ready to work...
That's a crap ton of TL072's for a hobbyist. Maybe we should organize a group buy?I said it somewhere here in the forum, but... If you get 100 pcs straight from Texas Instruments it's 55 cents a piece and you'll be 100% sure it's a original chip
I can easily go through 100+ TL072 in a month. Especially if I'm building a batch of Phase II/DuoPhase. And I concur that the Phasor II is the best phaser out there.That's a crap ton of TL072's for a hobbyist. Maybe we should organize a group buy?
They actually sell less, you can buy 25 pcs, and still less than 1usd a piece.That's a crap ton of TL072's for a hobbyist. Maybe we should organize a group buy?
Ditto on that! As I live in Brazil and it's really hard to find good chips here and most electronics stores sell counterfeit chips I usually order 300 - 400 pieces of assorted opamps every 2 - 3 months. They ship VERY quickly and very well packagedI can easily go through 100+ TL072 in a month. Especially if I'm building a batch of Phase II/DuoPhase. And I concur that the Phasor II is the best phaser out there.
I always leave mine at noon. I've yet to have any need to change them. One controls the overall brightness of the LED and the other the sweep symmetry. But it should be pretty perfect at noons.How did you calibrate the trim pots? Any trick to that or just adjust to taste?
R19 pin is awfully close to that LDR, as seen here;I really need to figure out why mine doesn’t work…
I don't remember where I got mine, but the rate goes CRAZY fast, you'll be fine with 20kDoes anyone know where I could find a PC mount 25k log potentiometer? I got a 20k one but I'm worried about the range of the rate.
Before this build came online, I literally bought the parts yesterday. I got the 25k log part from SmallBear. Tayda didn’t have it.Does anyone know where I could find a PC mount 25k log potentiometer? I got a 20k one but I'm worried about the range of the rate.
