Hi,
this is my first post and my third build so pretty noob.
I finished the Pitch Witch and it almost work, but there is no modulation in the pitch... I have bypass and FX Delay working but no pitching.
It looks like the yellow LED tension is not modulated by the JRC4558 (I used RC4558D Instead)
I don't really know how to troubleshoot this, but I tried genuinely (desperately) to put a Rainbow led in parallel of the Yellow Led, and there was modulation. But not correlated to the 3 potentiometers (Speed Wave Depth) so i guess it happened just because of the Rainbow Led.
I measured the output of the RC4558, 10,5 Volts constant.
I don't have anything to send a picture, but maybe a hint to understand how the things should be working ?
EDIT
At the first try, nothing was working because i used a weird 4pole footswitch and the wiring wasn't correct. Now the wiring is ok but Maybe, because of that, a bad routed 9v tension damaged the IC's ? How do you check them ?
P.S I'm not in the good section, sorry, should by in troubleshooting...
Thanks, Bests.
EDIT
Thanks, Bests.
