8 way rotary switch on my Rangemaster makes loud popping sounds sometimes when rotating the dial. Is this a defective unit or is there a way to fix this?
You could say the same thing with toggle switches with Gain options and Clipping options, they Bang & Pop!
All the boutique pedals??? do the same thing!
Most people accept it or turn the pedal to bypass & switch then turn the pedal back on.
I would have done that on the bottom side so it doesn't look so invasive!!!
Really though, the reason it works is when you make the TeePee, all those DEVO Energy Domes combine forces to protect your build by recycling your PCB's Orgone Energy away from the signal-sucking switch and back into the PCB's main signal path.
