joelorigo Well-known member Sep 27, 2022 #1 I harvested a pot from an abandoned pcb by snipping off the thin pins. Is there any reason I can't use the pot with wire/leads soldered on to the remaining thick pot legs and into a future pcb pad? Attachments IMG_6509.jpg 106.7 KB · Views: 14
chongmagic Well-known member Sep 27, 2022 #2 As long as it wasn't damaged it will work fine that way.
Harry Klippton Not Interested Sep 27, 2022 #4 I cut them off on purpose all the time to wire them without PCB mounting
joelorigo Well-known member Sep 27, 2022 #5 Yeah I've used solder lug pots before so I was assuming it would work.
