Productive weekend...3 new builds completed....and they all work! (sort of)
MichaelW
Not sure how I managed to spend most of the weekend at my work bench and not winding up with an "Angry Wife Plus" heh.
It was too windy to go fishing, so I wound up building pedals.
First up is a Paragon Mini.
I incorporated some of the mods I messed with on my first full size Paragon build. I used @ckaudioeffects "warmer tone mod" but oddly enough the "Paragon Mini" doesn't seem to suffer from the brightness that the full size one does. I probably could have gotten away with just building it stock. As it is, I actually have the presence trimmers up about 50% but it sounds fantastic.
I also changed R3 and R20 to 10k as per AnalogMan's schematic. The gain pot is a B250k (per @Chuck D. Bones) for what I think is the more elegant "more gain" mod.
The biggest challenge (and goof I made) was trying to expose the clipping switches to external toggles. I was originally planning to only use 2 toggle switches with Boost, OD, Distortion modes for each side. But I found out I could not fit a DPDT On-off-On toggle between the pots.....AFTER I drilled the holes...duhhhh. So I wound up reverting to SPST micro switches and put the second pair on the side of the enclosure. After drilling THOSE holes it dawned on me that I "could" have just put all 4 micro-switches on the left side in a row. Ah well, holes were drilled already and it works. I may buy another enclosure on my next Tayda order and re-house the pedal with a neater toggle switch arrangement. It was a absolute biotch getting all the stuff to fit but well worth the effort. And it sounds awesome.
I socketed the diodes and currently have BA282's and 1S133's in there. I tried some BAT41's in series for the hard clippers and they sounded pretty good with less volume drop (but also 1/2 the gain). I may mess around some more with other combinations. But overall very happy with this pedal. I'm planning to build the whole "family" of KOT pedals in this color scheme. (Paragon, Paragon Mini, and Pauper).
Next up, I built an Angry Andy Plus (JHS @ Plus) for a buddy of mine. We're both huge Andy Timmons fans and he's been wanting one of these pedals. Way more gain that I would ever use but it was a fun build, except that I'm not sure if it's working correctly. (That's the "sort of" in the title hahah!). I've started a separate thread over in the Troubleshooting forum to see if I can get it sorted. But the pedal sounds fabulous in "non-boosted" mode. Sounds better than I recall my JHS Angry Charlie did when I had it. I built pretty much stock. This was my first dual footswitch on a 125b pedal. I used the PedalPCB drilling template and I think the foot switches are too close together. I made some adjustments on the Paragon Mini which I drilled after the Angry Andy.
And finally I had a quick Sunday afternoon build of a Mayahana Drive. I actually have the PedalPCB Zen drive clone that I bought off Reverb that I really like a lot. But I wanted one that I built myself hah, and I wanted to house it in a 1590B. It was a super easy and fast build. Only changes to the PedalPCB spec was that I used an NE5532 Op Amp.
Oh and I did not have a 2M2 resistor so I had to Macguyver one together (it was either that or wait for one to ship out to me).
I'm not sure what diodes were used in my other "Reverb bought" pedal but I used BAT41's and a 1N34A with a good vF range spec. It sounds different than my other pedal, but in a good way. It's got a little less gain but overall smoother.
I only messed with it for about 10 minutes this evening with my PRS S2 Vela but plan to run it through the paces tomorrow with my Eastman T185MX and get my Larry Carlton on.....HAH. Love how this thing sounds!
For future reference, that 2M2 is an input pull-down resistor (to avoid popping on switch, doesn't impact tone). Value is not too critical, you can use anything between 1M and 2M2 there.
Good to know, I'm still trying to figure out what all these things do, that's a great tidbit of info for me, thanks!!
Top Bottom
