Kroars
Built a couple Promethium’s again, this time one of the two has a signal when bypassed but nothing when active. I initially thought I had a short to ground somewhere, but no continuity where there shouldn’t be. Started taking voltage readings and noticed some fairly big difference between the two at the 2N5457 (Q1) D-0v, S-0v, G-0v. Also at IC1 pins: 8-9.1v, 7-1.60, 6-1.60, 5-1.74
swapped all trannies and IC’s between the working Promethium and non working one, same result. So those all seem to be good. Every component tested prior to installation on both (built two at same time).
Solder joints are beautiful (even got a fancy flux pen I’ve been using. All legs snipped nicely and both boards thoroughly cleaned. Before I take it apart I’m wondering if someone could recommend testing a particular component that would feed either Q1 or IC1?
