Pyrocumulus Fuzz - tantalum capacitor ok?
Matth
Hi,
I’ struggling to find caps that are 25V Min and will fit on the pcb.
Can I, for example, use 1u 25V tant caps for C12?
Thanks
Matt
You can use 1uF film box or 1uF MLCC.
If you use tantalum make sure you put the positive lead in the top hole.
Oh ok... You said 25 Min so I was thinking maybe it wasn’t 9v... it’s happened to me before so I was just gonna check... thanks....
Cool thanks. I saw that some caps for this build were listed as 25v min and some 35v min. The pedal is working but the volume is low and not sounding great....
Mr PedalPCB notes it on the build docs I think. The capacitors need to be rated for more than the circuit voltage. IIRC they should be 2-3 times the circuit voltage.
The Pyrocumulus is strictly a 9V circuit so 16V caps will be perfectly fine.
You must be thinking of one of the PCBs that uses an onboard charge pump. (Triangulum, Integral Preamp, Isosceles, etc)
