thefooldog
Hi everyone! I started my first PedalPCB projects over the winter and had some successful builds with a few boost and drive circuits.
Surprisingly, I couldn't get my Rangefinder build to work properly.
Bypass works fine, LED turns on fine, but I get a thin-sounding, crackly version of the dry signal instead of any kind of boost. I'm using some Polish AY33S transistors that I believed were a feasible replacement for AC128, but I suppose those could be part of the problem. To try to rule out the transistor, I socketed and tested with a few different units from the batch of 20 that I bought, and I even tried reorienting the legs in case the pinout was not what I thought.
Here are some photos, the board is in pretty rough shape at this point after having replaced some components and reflowed the solder joints several times.
Any help would be appreciated, thanks!
