TucsonSean
I just finished up re-boxing my Paragon Mini. I needed a smaller enclosure so it could fit on my pedal board. I found the 1590B3 encolsure and I modeled it in Solidworks to make sure it would fit. I had to find smaller toggle switches since the old ones would not fit. I found some subminiature switches that were about half the size of the old miniature switches and moved forward with the reboxing. So here is my new setup. I got a painted enclosure from Hammond in a Cobalt Blue. I milled the holes and engraved the text into the box as I normally do. I was concerned that I would get some chipping around the holes and the text during milling so I covered the pedal in painters tape prior to milling/engraving. After running through the process, the tape may not have been necessary as no chipping was detected. The final step was to infill the text with silver or gold paint. I don't know if I will do that now. Overall I am very happy with the results.
-Sean
-Sean
