metalguy55 Member May 2, 2020 #1 Where can I find those little ribbon cables that connect the 3dpt breakout board to the pcb?
K Pedals Well-known member May 2, 2020 #2 Here’s one place Ribbon Cable, 2-Inch - 26AWG Pre-Tinned - 4, 6 & 8 Conductors Save time and simplify soldering with our pre-cut flat ribbon cable. Compatible with most common printed circuit boards for guitar pedal building. lovemyswitches.com
reubenreub Active member May 2, 2020 #3 Also check this out! WIRE, CABLES & PLUGS - Ribbon Cables - StompBoxParts stompboxparts.com
Earth Rocker New member May 2, 2020 #5 I found this on Amazon. 25 feet for $10. 4 pin, silicon coated and you can choose what gauge you want. I just finished using it in a wrectifier build I completed on Thursday. Works great for me. BNTECHGO 26 Gauge Silicone wire spool 50 ft Black Flexible 26 AWG Stranded Tinned Copper Wire - - Amazon.com BNTECHGO 26 Gauge Silicone wire spool 50 ft Black Flexible 26 AWG Stranded Tinned Copper Wire - - Amazon.com www.amazon.com
