Aquaticwombat
My friend's dad is convinced it is the greatest distortion of all time. I think he might be a Boston fan.
Upvote
11
Just to be clear, as I wrap up this mouser order, I only need one 2N4338?The Ultimatum is distortion only. It has a Gain control but it's basically more or less distortion, it doesn't get X100 cleans.
It does have the compression circuit.
I'd love to tackle some of the Rock Modules in the future.
damn itYou might want to hold off on the 2N4338 right now, that one is going to need to match a particular spec.
While Mouser does have the 2N4338 N-Ch JFET, you may want to take a look at some of the reliable sellers on eBay. Mouser wants 12 bux apiece for the 2N4338. There are some reliable sellers on eBay that have the 2N4338 for about 2 bux each.Just to be clear, as I wrap up this mouser order, I only need one 2N4338?
Any other exotic op amps/parts I'll need in hand?
Ack! I need to make a correction! (I've already corrected the JFET type number in my response above.)Interesting stuff! And much appreciated. I have plenty of those that you mentioned laying around so maybe I'll be all set.
Can't wait to finally play through one of these things, thanks in part to your counsel
You might want to consider a surface mount JFET for the compressor. Far cheaper than through hole, and it's probably not too much to ask of people to solder just one 3-pin SMD component (or perhaps you can sell the boards with the JFET pre-selected and pre-soldered). I've had good luck with the batch of MMBTJ202 I bought, but as usual with JFETs, YMMV. To measure and sort them, you might want to invest in a SOT-23 socket (they do exist). The compressor JFET is the one critical part of the whole thing.The eventual plan is to be able to select the appropriate resistors for the transistor, so if you already have one hang on to it.
Just don't run out and buy one right now if you haven't already, it might be easier (and cheaper) to sort through a group of more commonly available substitutes.
Cool! Any chance I can get the traced schematic of the Ultimatum? I love to compare the various Rockman design iterations.The PCB is laid out for SOT23 or TO-92. I have a reel of MMBFJ201's ready to go, considering offering them pre-soldered.
It'll be released this week.
Groovy!The PCB is laid out for SOT23 or TO-92. I have a reel of MMBFJ201's ready to go, considering offering them pre-soldered.
Just in time for the Labor Day Sale…womp.
