Aquaticwombat
My friend's dad is convinced it is the greatest distortion of all time. I think he might be a Boston fan.
Upvote
11
Now the big question is...did the Acoustic pedal from the same series mimic the CLN1/CLN2 settings?
The comp tends to suck out the bottom end a bit (per the original) so it might be worth exploring having the comp switchable.
Gordo - based on what I've heard from other Rockman gear heads, is that the Rockman Acoustic pedal is supposedly the exact same CLN2 setting of the Rockman Sustainor without the bells and whistles like smart gate, phase notcher, etcNow the big question is...did the Acoustic pedal from the same series mimic the CLN1/CLN2 settings?
That would make sense, as CLN2 sounds like an acoustic guitar simulator to me.Gordo - based on what I've heard from other Rockman gear heads, is that the Rockman Acoustic pedal is supposedly the exact same CLN2 setting of the Rockman Sustainor without the bells and whistles like smart gate, phase notcher, etc
I tried making the compressor "variable" in this circuit when I breadboarded it. But it's different from the compressor in the X100 in that the gain of the associated opamp is fixed with a 160K neg feedback resistor in the X100. (Tom did the X100 that way in order for the compressor to work consistently in all four 'Modes' of that circuit. And that fixed gain tends to allow the compression to be varied by simply adding a B250K pot (in rheostat fashion) between the output of the Gain opamp and where the compressor section meet at the 470Ω resistor. (In the X100, that resistor is 390Ω)The compressor can be made variable but I wanted to keep things as close to stock as possible on this one. It'd be fairly easy to hack one in offboard though, since there's plenty of room for an additional knob.
I want to say the acoustic pedal uses a BBD for some sort of notch filter, but I may be confusing it with something else.
I love the black capacitors, are those MLCC?I see my MaryAnn walking awayyyyyyyyy….ahhhhhhhhh…AHHHHHHHHHHH [blood vessel bursts in forehead]
Yep. Vishay. There are a couple of SMs in there as well.I love the black capacitors, are those MLCC?
Robert
Black cap bones?Yep. Vishay. There are a couple of SMs in there as well.
You can’t just show us a build in a limited edition LMS green sparkle enclosure without showing is the front too!I see my MaryAnn walking awayyyyyyyyy….ahhhhhhhhh…AHHHHHHHHHHH [blood vessel bursts in forehead]
Robert
fig - what JFET did you use and did you measure it's Vgs(Off) before installing it? If so, what was the value please? (Just curious. I found several J201s with a Vgs(Off) at ~ -0.98v)It's green.
Must be hungry, I see lot of tiny sausages in there ! What are those resistors ?Yep. Vishay. There are a couple of SMs in there as well.
