vigilante398
Authorized Vendor
Which circuit are you looking at? Am I missing parts?I was putting the resistors on the board and realized the build doc doesnt have the 470k resistors. I'm all out of those but I might have enough 422k and 51k to put in series in those spots. Would that be a bad idea considering the sensitivity of these circuits?
Depending on what you're looking at you could possibly get away with just using 422k (which is a weird thing to have on hand and not have 470k) across the board without changing the output too much. They are a bit sensitive to wiring and dress, so it's generally better to use a "wrong" value in order to keep the build tidy.
Tube circuits are sensitive to a lot of things, but resistor values isn't really one of them. I've substituted things that were 25% off value in a pinch just to see if the circuit works. Worst case scenario it just sounds a little different.
