BLUEBEARD MUFF
BlueBeard, a Muff meant for Bass, yet still only uses 100n caps; shrouded in controversy because GGG built them for Sonny, and then offered a “TUNED MUFF” kit later that appears to be the Bluebeard…
MY LINKS:
#7
"Ahhh, looked again — Found It. It's not listed as "Tuned", just as "General Guitar Gadgets Version":
Schematics | General Guitar Gadgets"
RCUBED
Here is General Guitar Gadgets' official response:
GGG:
"There have been some misunderstandings about this version. GGG is involved with building a pedal by Sandford and Sonny called the Blue Beard bass distortion. This "Tuned Version" is somewhat similar to the Blue Beard, but it is not a Blue Beard. It sounds somewhat different and it is in a smaller box of course. This is an excellent distortion for bass or guitar or synth, but this project should not be considered a kit for a Blue Beard pedal."
[see FenderHutz’s comment in green below, JD is fibbing here (or there)]
Personally I think it's the same schematic with some possible component changes (capacitor or resistor values or slightly different transistors or diodes).
MIKEBOTH:
... all the resistor values I can see are exactly the same.
Edit - I have it. It must be the marker scribbled on the unfinished box that makes all the difference.
RUSTY NUTS: “ - resistor values from screenshots look to be exactly the same”
Aye, but the component numbers are different, and I don't think anyone's seen a diagram of both side by side. Resistor values are the same, but are they assembled the same?
KARATEKID25: [re SILICON DIODES]
The exact readings where around 0.602 - 0.604 volts for all eight diodes.
PHARAOHAMPS:
The board in the unit on the left [BLUEBEARD] is the old GGG Big Muff Pi DIY board. JD Sleep at GGG made that layout available several years ago, and it's pretty well known in the DIY world. I know I've built 2 or 3 BMP's on that layout. The board on the right with the GGG silk-screen and green solder mask is one of JD's new boards. As to component differences, without knowing the values on the poly caps (shiny round-ish blobby ones) I can't speculate. However, the GGG tuned Muff has much smaller values for the interstage coupling caps [PRESUMABLY MEANING THE STOCK MUFF, NOT BLUEBEARD {but then mentions blattiness of stock muff…>}]
, which roll off the bass from clipping stage to clipping stage in the pedal, and prevent the gross blattiness of the stock Muff.
Are the two pedals the same? It's certainly plausible. S&S may have some tweaks that they're making to the stock Muff. I would bet that the cap on the LED is to prevent popping during switching, since the voltage drop caused by the LED turning on can mess with the bias voltages on the transistors in the pedal.
Sure, the kit is less expensive, but if you're not up to the task of building the kit, I'd say the Bluebeard is probably a pretty decent deal. I know I have seen pedals that weren't made as well selling for more money.
rratajski:
The pots are the same, A100K x 2 and B100K on both the GGG and BB.
[WHICH CONTROLS HAVE THE A100k and which the B100k?]
help-me-talkbass-must-find-bluebeard-fuzz.1296840/#post-20284954
DUNWICH’S BLACKBEARD MAY BE THE SAME MUFF
and from my own post in the above thread, links to …
https://www.talkbass.com/threads/sanford-and-sonny-bluebeard-fuzz-kit.375367/
ANDREW:
Robopedals have teamed up with Sanford and Sonny to make the Bluebeard available again.
[True when originally posted in the thread, currently though?]
Sanford & Sonny Bluebeard
http://guitar-fx-layouts.42897.x6.n...-Sonny-BlueBeard-Fuzz-Distortion-td20220.html
BLUEBEARD IS GGG TUNED WITH FOLLOWING MINOR CHANGES
- a 47 ohm resistor between 9v+ and the circuit,
- another 220uf in parallel with the one from 9v+ to ground,
- and a 4.7k resistor instead of 1k for the LED.
So nothing that would really change the sound much.
“Hello my name is Sonny friend of Surachai. I would like to clear up some things. Along time ago i tried a 70's lamb's head big muff that sounded very girthsome for bass. The guy Brian would not sell it too me but let me take it to Alfonso Hermida (www.hermidaaudio.com) to copy so that i could have a true bypass version with a barrel type power supply and a sturdier more beer proof hammond box.
I am not an electrical wizard ALL credit goes to Alfonso. Alfonso said he had a friend who could make the PCBoards in small batches of ten this man's name is JD Sleep El Presidente of generalguitargadgets www.generalguitargadgets.com Once i heard the prototype and a few changes were made my one pedal was going to be a batch of ten as I had several friends who wanted one.
JD wanted to move into eventually making pedals full time and we struck a price for 10 assembled. Years and many pedals later I still do not have a web site just a myspace. JD makes pedals for lots of people and oh yeah the lack of paint... When I had the first ten no one wanted to wait for them to be painted and i didn't want something cheap that would just flake off like a lot of projects i had seen I think it would make the build seem cheap.
So i looked into powder coating and with every batch i had people waiting saying no just give it to me and after 50 pedals and def after 100 I gave up on the idea of painting them and the idea of engraving or stamping did not work out so well. So I have nothing to hide and all I do is sell to friends and people who hear about me through friends. I pay JD to make the pedals. I do not [make the pedals].
There are a lot of things to talk about in the world and a lot of things to spend time doing on the net but when anyone asks I tell them JD built it and if you get something you want built he is THE man he is now able to build pedals full time for a lot of other people.
I pass the pedal on to people who want it and in the, i guess 5 years i have been doing this I have always said if this pedal does not work with YOUR rig then you can return it for a 100% refund the only people I have had problems with is some dude that bought through Atomic and was more concerned about hatin’ online when he could have gotten his money back in full.
I do not say that this pedal is the end all be all I waited for the EH BM reissue i even stupidly waited for the line 6 distortion modeller before i made it. I like to use an EQ after but not everyone does that is why i make it as a replacement for all the thin black eh out there. I like the green ones but the backdoors and the switches sucking oh yeah and being hella spensive.
Well I never pretended to be anything other than a nerd looking for the best bass sound ever I talked to Mike Matthews about the buckets of parts put into the 70's pedals there is a wide variety of parts in them all and the pedal i copied had aged a few years I am trying to build a pedal for people who want a solid pedal that will not crap out on them in ten years and will be just as awesome when they are old. man i hate typing.
I have only taken out one ad and that was for an independent publication "give me back" everyone else is word of mouth like surachi. I am already overwhelmed with orders i don't know what S&H to Denmark is. I do NOT want to sell to crappy blues smooth overdrive guys I want to sell to people who kill kill kill. I am not putting out myself as anything other than a conduit. if you don't like the taste don't drink the water. I am not gonna proof read this I have to go play bass now nite nite Metal, Sonny”
ADAPT: this is the GGG tuned muff with the additions i specified. there's a thread on talkbass where they compare the two, the GGG and the BB circuit-to-circuit, and the additions i made are literally the only ones, 47R resistor from power supply, extra cap in parallel (which i combined from 440 to 470uf) and the 4.7k LED CLR. i am sure the toggle switch is just a bigger capacitor on the input.
[no, it’s a tone-bypass switch]
GUT SHOTS OF BLUEBEARD & GGG
https://www.talkbass.com/threads/th...-now-im-peeved-off.450447/page-4#post-6226313
#18 FENDERHUTZ:
If you want a kit that is to spec of the Bluebeard in a smaller form factor for 71.00 dollars, buy the BMP distortion box tuned "GGG" www.generalguitargadgets.com
JD told me it is the same config as the Bluebeard, just in a smaller box.
NIFF:
it's a modded russian big muff… but, modded to hell. it seems to have really amazing clarity and range.
BassJunkie730:
It's really not modded to hell
only about 6 or so values are changed and they aren't as radical as your think.
[What 6? Modded to hell? One resistor and one parallel-cap for power-filtering...]
