Should I buy a wah pedal or build one?
falco_femoralis
The enclosure is 35 bucks anywhere, the board is going to be 20 after shipping, then there's specialty components I'll have to order plus shipping, or I can buy a used cry baby for 70.
What's the deal with different wah pedals? Do they not all do the same thing? If I build one can I make some special unobtanium circuit like what we normally do?
I have 3 cry babies right now, 2 modded and one that is broken I plan onm using for the Sham Wah.
Find a busted one cheap and use the enclosure or fix it/mod it.
I say build it, you will have much more fun building it than the 30 minutes you will play with it before it ends up a door stop
Well maybe I’ll dust mine off and see if I still hate Wah pedals.
Blech. Welcome to my shit list. Population: you.
For not liking wahs. I think. Wait, is having a wrong opinion bad? It feels bad.
No, no, I think I'm right here.
Anywho...wahs. wah wah wah. Wahdie wahdie wah. I love wahs. The Tearjerker PCB is quite good, but is at its core not a different circuit from the standard gcb-95.
The primary difference is the tweakability: the tearjerker replaces several resistors with potentiometers, and allows for multiple different caps to be switched in parallel so you can find tune the range. It's a solid platform, but the number of options can be a little overwhelming.
My personal preference is to have a Jfet buffer before the wah circuit rather than a bit. Helps to retain some of the high end that could get lost due to the low input impedance of the circuit, plus I just feel that the Jfet buffer lends itself to a livelier response. That's the lie I've told myself anyways.
The Sham Wah board is pretty easy to modify for this purpose. So is a standard crybaby circuit board. The PPCB Jfet buffer board offers up a good example schematic. Without the 10uf on the end.
Overall, though, there's not much difference between 90% of what's out there. Rocktron's wahs are made by Eleca, tend to have solid inductors, but their boards are a bit unnecessarily cramped. Crybabies are good modding platforms, but modern day variants tend to come with toroid inductors, which I've found myself to not be particularly fond of. Yes, the red and yellow fasel that so many seem to love; not a fan.
That said, the SBE ME-6 is excellent. Really quite good. Cheap too. Although you can always get one custom wound by your friendly neighborhood stickman if you don't mind a "when I get around to it" timeframe.
Transistors: I'm a basic bitch here. I really like the BC109b in a wah pedal. Honestly, you probably won't notice a difference with the BC549b: it's cheaper, and it's basically the same transistor.
2N3565s and PN3565s are great too. I shoot for 200-300 hfe in Q1 and 300-400 in Q2. Higher gain in Q1 will extend the range...which can definitely be a bad thing.
MPSA18s don't belong anywhere near a wah. Too clean, too hot. Never understood why this became the go-to.
The range cap: I, personally, like to make this one a polystyrene cap. At the very least, polypro.
Little mods: drop the input resistor from 68k to 47k. Adds a little bass/gain. Drop the emitter resistor on Q1 to 330-390r. Play around with the midrange feedback resistor on Q1's base. Stock is 1.5k, 1.8 is about the upper limit for me on that one. Q resistor: anywhere from 68k to 100k.
And...honestly...because I believe in magic, I like to replace one of the 220nf caps (the upper cap leading to one of the end terminals, not the one attached to the wiper) with a 680nf polypro, and I swap the other 220nf polyester cap for a PPS variety. Because magic.
Honestly...it's a little tricky. Theres something really great about getting that vowel-like tone just *nailed* in a circuit, but it takes some patience.
Also, the above are just my own mods. Feel free to explore to your hearts content.
I thought about the same thing off and on for a while. Then I bought a used mini 355Q that has enough tweaking abilities for me, for now at least. Wasn’t sure if I would dig the mini-ness of it all but it’s fine, for now at least 😀
I went with purchasing the CBM95 because it is small and sturdy and in a live mix a wah is almost always going to sound .... Like a wah. After seeing enough gigging musicians use it with success.... (Indeed... It sounds like a wah) I was able to get over the urge to compensate for my skills with a large treadle rocker at my toes and I managed to somehow live with the shame of knowing that I have not built that part of my kit.
If I had to do it again I would.
I've got a dog with long hair. Its EVERYWHERE
Must be having "dust-puppies", 'cause that "dust-bunny" had eyes.
Sorry to tribble you...
Have any of you futzed with the Colorsound TwinT wah? It’s the base wah used in the SeekWah/OohWah.
Personally, I haven’t had a wah since after college. I should have never sold that BuddaWah.
I suspect the only people who like wah pedals are the people who play them. The rest of us just get on with making music. Or other pedals.
The instances of a wah pedal actually being expressive and musical are rare. Jimi Hendrix is probably the only player I've heard who used it well. Most of the time it's just an irritating noise. I cringe every time I see a guitarist play "the wah solo" at a gig.
A'ite. Ok. No. @Paradox916, you're fine.
Hamish. Shit list. You on it.
*Stares daggers*
The urge to build a DIY wah is strong even though I already have a crybaby in a box somewhere that I never use.
I’m gonna go out on a limb and say, you are not a Snot fan.🤣
