I still need to dial in the string gauges. Tension feels a little low with B-to-B tuning. I've got a set of Dadarrio Jazz Mediums on it. (Not sure why they're for "jazz".) But they rattle if I hit the strings too hard.
I'm also thinking about experimenting with some Nashville tunings.
I used those on my 27" scale for years but recently switched to these. I know I'm weird but I'm definitely not switching back any time soon. An expensive risk if you end up hating them but I'm way in to it. Again, this is from a bassists perspective.
Ariel Posen uses 17, 20, 30w, 40w, 52w and 64w for B standard. Joey Landreth uses something close to that. That will give you something close to 010 E standard tension.
It's my dual Deluxe Memory Man delays. (MBP Skoolie on my amp rig). I have the same set up for my amp-less rig (MBP Total Recall + MBP Tourbus). Slight touch of reverb from a Gravitation Reverb on both setups. Basically, I'm reproducing the early 2000's Andy Timmons setup when he was still using DMM's to create his "Halo" delay effect.
