SOLVED Simulcast quiet/thin sound
okstateblues
Thanks up front for any help. Everything works but it is super quiet even at 100 percent on the knobs.
All your values and orientation look correct
Post a pic of your offboard wiring to jacks switch etc
It could be a number of things most likely the usual cold solder joint in the audio path, on the jacks or 3PDT incorrect wiring etc
Is it ok bypassed
Yes it clears. However I did notice that the green wire going from my footswitch to board isnt all the way thru the hole on the board. May need to reheat and coax it further through. Would the burnt insulation have an impact?
Not unless it shorts on something like the lid
Yes just heat your solder joint for around 4 seconds and gently push your wire through
do you have low volume throughtout the tone pot rotation the one I built had a couple of blank spots at the beginning and end of the tone pot rotation @Chuck came up with a solution that worked
One thing I can't check is your transistor pinout what did you use for the OC71
I'd personally get the audio probe out to find where you loose volume
Do you have an audio probe? there's nothing obvious that I can see the OC71 looks correct from what I can see should have a red dot on the collector, audio probing the circuit will get you to the problem area pretty quickly
That's correct red dot = collector, base in the middle and emitter goes to the pad with the small tag on the silkscreen, some metal can type transistors have a small metal tag on the body indicating the emitter pin
Does your level pot act like a level pot ie goes off when you turn it down etc and nothing you can see is touching the bare metal enclosure
The reason I ask all this is from your description you do get effected signal which would indicate a high resistance to the signal making it through the circuit which could be a dry solder joint in circuit etc etc so whilst you wait to construct your audio probe I'd reflow the joints indicated in red and make sure all of them are good, obviously take care with the 3PDT lugs you don't want to heat them for too long
The fact you get bypass signal tells us the wiring to the jacks is ok doesn't tell us much else
