Asbestos is only dangerous when disturbed. Having it on the house or the wrapping of your pipes does no harm... It's when you tear it off and the dust is flying that can get you... That's why you see mesothelioma in guys who worked as boilermakers, steam fitters, etc... if you happen to get exposure once or twice you'll probably be fine... it's continual exposure to the dust that gets people... Lots of old timers were maintenance guys, plumbers, HVAC guys, etc that have the issuesMy house has asbestos siding…I use lead-free solder, but only because I still have a bunch. I’ve had no issues…
If only 63/37 was available where I liveLead does not vapourize at 732F, the boiling point of metallic lead is 3180F (1750C) - none of the components of any solder are volatile at their working temperatures. Thus, thankfully we are not worried about lead vapour when soldering, you're right that it's just the touching and the flux fumes.
Also you guys should try 63/37 solders, they handle much better than the 60/40s![]()
Of course. Spatters on fingernails. When I clean a board I use IPA on my hands too.You guys are getting flux on your hands??
So just wear a shop coat when you go buy itI can't be arsed to dig up the laws or anything, but AFAIK you can still buy it for professional use in Finland, just not for hobbyist use.
You know I thought that was awfully low for vaporizing when I saw it. As long as it doesn't get in your stomach you're ok, people live long lives with bullets inside them. It's insoluble in water, hydrochloric acid however does dissolve it.Lead does not vapourize at 732F, the boiling point of metallic lead is 3180F (1750C) - none of the components of any solder are volatile at their working temperatures. Thus, thankfully we are not worried about lead vapour when soldering, you're right that it's just the touching and the flux fumes.
Thats awesome. The picture. Me. Too many times to count no idea if there was lead or not.As long as you don't solder like this, you'll be ok:
(For those who don't know, that's Apple's founder Steve Wozniak).
Lead is dangerous especially if it enters through the mouth (ingesting or inhaling). As long as you don't touch anything that you're going to eat later and you manage the fumes, you really need to wash your hands after touching solder as a preventative measure. Use gloves if you want to avoid any risk of skin absorption (but there are not a lot of info of how dangerous it is to handle lead in its metal form, as studies are more focused in organic and inorganic lead compounds used in the industry). And don't let kids handle anything that has lead, as it's especially harmful for them and their development. Just be cautious.
I do use 60/40, but luckily I don't solder much, so I'm not constantly handling that solder. And I'm thinking of start using the assembly services of PCB manufacturers, that can use lead free solder paste and safer methods of soldering.
But if you decide to use leaded solder, please! don't hold the solder with your mouth.![]()
I thought that as well. Thought he may have been confused with 732C.Lead does not vapourize at 732F, the boiling point of metallic lead is 3180F (1750C) - none of the components of any solder are volatile at their working temperatures. Thus, thankfully we are not worried about lead vapour when soldering, you're right that it's just the touching and the flux fumes.
Thanks, my man! This is relevant to my interests.I go between soldering and smoking pretty often without washing my hands so I'll let you guys know if I die prematurely
