I put together the Spatialist (FV1 soldered on by PedalPCB) but am having issues. More doesn't work than does work.
1. Volume pot is functioning backwards....full left is max volume.
2. Mix pot acts as volume also, so I m assuming "max volume" on the mix pot is actually a full dry signal and "no volume" is full wet.
3. Top 3 pots do nothing at all.
4. Rotary switch causes no change, but I can hear a dull thud when I switch it. Causes no change to the sound and all sound just like it's bypassed.
I also included a screenshot of the oscillating crystal I'm using because I had some on hand. It's the same frequency as the one in the BOM but I got it from Tayda so it might not be an exact match. Wondering if that might be the issue because it seems like the FV1 is not functioning as it should.
